Engine bay show 'n' go:
*Tuned by @turbotekray of
https://www.facebook.com/TurboTekTuning - 305WHP/360WTQ
*Cobb Tuning Accessport
*Blouch TD05H-18g 8cm2 turbo
*FMS intercooler w/ heat coating & DEI heat tape
*Process West intercooler shroud (the 09-13 FXT spec one)
*FMS STI layout turbo tube w/ DEI heat tape
*ID1050X injectors w/ PnP adapters
*DW65c fuel pump
*OEM intake box/K&N filter...more DEI heat tape
*Grimmspeed 3port ebcs
*Grimmspeed high lift hood struts
Hood Struts - Subaru WRX/STI 08-14 - GrimmSpeed
*CNT catted downpipe w/ wideband bung
*OEM midpipe
*Nameless Performance axleback
*GFB TMS Respons Hybrid BPV
*ThermalZero turbo blanket
Thermal Zero LLC - 513.696.WRAP - High Temperature Heat Solutions
*JDM LGT OEM PS cover
https://www.japanparts.com/
*JDM LGT OEM battery cover
*DIY intercooler sprayer with @Mishimoto 850cc resevoir tank (PN:MMRT-CA)
*Perrin brake fluid koozie!
*Perrin alternator cover
*Perrin turbo inlet
*Perrin Afta-MAF
*IAG oil fill cap
*IAG coolant overflow cap
*IAG master cylinder cap
*IAG power steering cap
*IAG washer fluid cap
*MOORE Performance turbo heat shield - Special Edition # 001!
Moore Performance & Race Parts, Pittsburgh PA
Suspension:
*2011-2014 WRX OEM "donor" front struts w/ Koni 8610-1453Sport inserts
*Koni rear shocks - 8010-1055Sport
*GroundControl - 08+ impreza Coilover conversion kit
*GroundControl - "GC150.64.77" spring (4)
*Eibach - "SPACER250" 2.5" I.D. Spacer/coupler (4)
*Hyperco - "CS100" 2.5" I.D. 4" Free Length Steel Helper Spring (4)
*Whiteline Com C caster/camber front mounts - #KCA409 (kit)
*Subaru OEM rear strut mounts (2)
*Perrin rear subframe lock down kit
*OEM 18mm sti (2008) rear sway bar
*ISC V2 adjustable rear lower control arms
Brakes:
*Centric Premium rotors
*Hawk HPS5.0 pads
*Grimmspeed MCB
*Motul RBF600 fluid
Interior:
*WRX steering wheel with FXT buttons
*Subaru JDM OEM paddle shift kit
*SMY cluster surround
*AEM UEGO wideband
*AEM boost gauge
*Busted Finger wideband/serial cable
*LGT OEM shift knob
*WRX OEM center console
*WRX OEM ebrake assembly
*JDM OEM WRX/STI center console additional storage/armrest
avoJDM Parts Online
Wheels/tires:
*Enkei RPF1 18x9.5 +38 wheels
*BFG COMP-2 A/S 255/40 tires
*Muteki SR48 lugnuts, aluminum hub rings, yada, yada.
Misc:
*Diode Dynamics SmartTap CF18 (LM449) Flasher Relay
*Diode Dynamics D2R (6K) low beam HID
*Diode Dynamics HP3 (6K)license plate LEDs
*Diode Dynamics HP3 (6K)parking light LEDs
*Diode Dynamics HP3 (amber) side marker LEDs
*Diode Dynamics XLM2 (yellow) fog light LEDs
*Diode Dynamics HP48 (amber) turn signal LEDs
*NOKYA jdm yellow high beam/DRL bulbs
*Blacked out interior portion of headlights
*Grimmspeed front license plate delete
*Grimmspeed rear license plate frame
*Mach1 mustang front lip
*RalliTEK 4eat trans mount insert
*Rola roof basket
*OEM cross bars
*OEM sport grill
*OEM rain guards
*Painted yellow fogs/rings (with stained glass paint..rattle can from Krylon)
*Perrin shorty antenna
*OEM JDM "F" badge
* @VarcoRep LED Rear Reflector Bumper lights
Some favorites from along the way:
