The 2000 should have the same sort of suspension setup. Not sure how the springs would fit on his struts, or if you would need the whole takeoff strut+spring. I'd give it a try and see how it goes!ahh i checked with him its a 2000...would this be an issue? i have an 04
and i think its actually his goal to be an offroadKANG
Ah you're right, I was one generation off. So 99+ uses the control arm setup in the rear, so none of the suspension parts will swap over.I think the 2000 Outback has a different suspension setup in the rear (shocks instead of struts).
