I finally get my new FXT 14. But, I feel that the suspension seems to have lots of vertical movements even over normal road irregularities (compared to outback). Can installing a 19mm RSB help? Or any other options?
I did checked the tire pressure at dealership. All of them are 42psi. So, I released some air and made the front tires at 38 psi and rear at 37 psi (now, it is very cold in Chicago).Quite a few people have said the tire pressure was way too high when they got theirs >45 psi. Try checking that. It also has a shorter wheel base, thinner tires, stiffer suspension, and harder seats compared to the Outback, so there's that.
Ok, I will try to lower psi. but change to 17" wheels is impossibleFor smaller bumps tires make a huge difference. Firstly, for FXT the psi should be much lower, IIRC 33/32.
To dampen small bumps even more change tires and/or switch to 17" wheels.
I keep with the specs (33/32 psi) and feel comfortable. But I also had 1 time 3 people on the back seats and a lady complained she felt a little bit sick (I was driving slower than usually in this case).For smaller bumps tires make a huge difference. Firstly, for FXT the psi should be much lower, IIRC 33/32.
