Full Size Spare for '09 and '12 Forester
I decided to buy a full size spare for our new 09 Forester X (PZEV 5MT Premium w/ AWP):
Aftermarket f/s spare (mounted and balanced) from Tirerack (US$130 + shipping):
Yes, I test fit the new f/s spare, and all is well.
And, speaking of “wells”, the f/s spare fits into the spare tire well. The circular jack organizer fits inside the 16” wheel, along with my circular tool bag, and the cargo area floor still lays flat, but I had to give up the molded rectangular tool organizer.
The full-size spare’s specs are “close enough”, in my view, to the base model tires and wheels, as well as to the “Premium” and “Limited” tires/wheels. For example, the OEM 17” tire’s diameter is 26.8”, and the new f/s spare is 27.0”. The f/s spare’s “T” speed rating (118 mph) is lower than the OEM’s “H” (130 mph), but it’ll do.
The Rims-n-Tires calculator puts the 17” OEM tires at 753.7 revs per mile, and the new f/s spare at 747.1 revs per mile – a less than 1% difference. The OEM temp spare calculated out at 788.5 revs per mile – a 4.6% difference from the OEM tires.
Subaru requires that all tires be within 1/4 inch rolling circumference. Tire Rack's mfr specs for the OEM tires is 775 revs per mile and 772 revs per mile for the Kumho spare. The math indicates a 0.32 inch difference in circumference. This is slightly outside of Subaru's spec, but it's far closer that the 3.7" difference -- almost 15 times Subarau's circumference difference spec -- between the OEM tires and the OEM temp spare.
Nov 11, 2009 Update: I measured the tires and wheels:
I think this combo is a satisfactory and cost effective solution, and I also think the price was quite good. Service was excellent: I ordered the tire on Sunday, and it was delivered on Tuesday.
I hope this info is useful to others.
Regards,
Jim / crewzer
Nov 10, 2009 Update: The Dunlop SP 60 all-season tire in size P215/65R16 98S (600 A B) is well reviewed in Tire Rack's survey, is also modestly priced, and is spec'd at 776 revs/mile. The calculated difference in circumference between 775 revs/mile (OEM 17" tires and wheels) and 776 revs/mile is 0.105" -- well within Subaru's 0.25" spec. Based on calculations and measurements above, this tire might be a "better match" as a F/S spare for the OEM tires.
Nov. 13 update: Some sizes of the Dunlop SP 60 are whitewalls. This may be why it didn't show up during a "vehicle based" search. However, it does pop up when searching for a 215/65R16 tire. Dunlop's website indicates the 215/65R16 is a blackwall.
Nov. 13 update #2: I also purchased a set of mounted 16" winter tires. Here's a summary of key dimensions and specs for the various tires:
March 26, 2012 Update: Kept f/s spare when '09 Forester was sold; moved it to '12 Forester.
OEM tires: Yokohama Geolander G95 P225/55R17 95H 320 BA
OEM wheel: 17” x 7.0”, ET (offset) 48mm
TPMS sensors (4)
Stock Spare tire: Bridgestone T155/70D17 110M "donut" space-saver; no TPMS sensor
TPMS sensors (4)
Tire: Kumho Solus KR21 P215/65R16 96T 680 AB M+S
Wheel: Stamped steel, 16” x 6.5”, 5-100 bolt circle, ET (offset) 50mm, 56mm centerbore (cb)
No TPMS sensor
No TPMS sensor
- Kumho F/S spare's static circumference: 84-3/4"
- OEM tire's static circumference: 84-1/4"; 1/2" (0.50") shorter
Regards,
Jim / crewzer
- OEM tires: Yokohama Geolander G95 P225/55R17 95H 320 B A, 84-1/4" circumference, 775 revs/mile
- F/S spare: Kumho Solus KR21 P215/65R16 96T 680 A B M+S, 84-3/4" circumference, 772 revs/mile
- Winter tires: Dunlop SP Winter Sport 3D 215/65R16 98H, 84-3/4" circumference, 770 revs/mile
