Will Koni inserts and Eibach lowering springs or Sti pink springs in Forester (Sti) strut housings be an issue or would I be better off using WRX/ISTI strut housings?
The question is regarding the lifespan of the inserts and springs.
It was mentioned here that using Koni inserts on the FXT housings caused the springs to wear (post#7):
http://www.subaruforester.org/vbull...mpreza-fitment-springs-forester-struts-34436/
Also what are the part numbers for the Koni inserts that I need?
I have PMed Porter but he has not been around since January.
Also here it is mentioned that Whiteline springs are not recommended but STi/SPT pink ones
http://www.subaruforester.org/vbulletin/192242-post36.html
Does anyone have the rate if the above 2 springs?
The SG9 Sti pinks (FSTI specific) are 36N/mm front and 34N/mm rear and want to know if they will work with Koni inserts.
Also what are GR2's?
Thanks
Thanks
