Getting ready to pull the trigger on a new FSB. Currently running the stock FSB/links with the following suspension mods:
Swift springs
Subtle fender braces (cowl stays)
STi 20mm RSB with KB links
mo_boost support brackets
subframe locking bolts
Whiteline rear strut tower brace
alignment = -1.5 degrees camber all 4 corners
I don't want to go too heavy on the FSB as this is a DD, but with the above mods the need for a heavier FSB has become obvious. I already have a set of KB links to use.
So, would a 22mm bar be a worthy upgrade? Or should I go to a 24?
TIA for your input!
Swift springs
TIA for your input!
