1 - 20 of 80 Posts
The Modfather
2004 5MT XT
I've got 'em. They've cured the chronic smearing, skipping and chattering I had with the OEM blades, plus two different aftermarket brands. They're by far the best blades I've had on the car. The aero design really works.
However (there's always a however!), as expensive and trick as these blades are, at low speeds the outer tip (maybe an inch or so) still fails to make full contact with the glass at the low end of the sweep on the passenger's side. Highly recommended in spite of this minor niggle.
The Modfather
Yes they were not cheap, I got mine for 20 for the drivers side and 18 for the passenger side. AutoZone has a $15 gift card rebate going on right now. I just filled my paperwork out just now :)
They look very much like these here:
http://ultimatewiperblade.com/
2004 5MT XT
You mean the 15$ gift certificates that I promptly threw away after I got home from AutoZone, I assume. :(
I've been using the "Bosch MicroEdge Excel" and have been satisfied with them. I put about 25k on my car a year, and I put new ones on every Fall.
They are alittle cheaper too ($12 for the front and $8 for the rear).
The local PepBoys carries them.
Dom
The Modfather
I've used the micro edge too, and they are just OK, what I like about the Icon blades is they have the air foil. I'm hoping they help keep the blade on the windscreen. We get a fair amount of cross winds here in KS. Also, not having any metal exposed should make them less likely to ice up. That remains to be seen though.
I just picked up a set of these also.. expensive! But, the LOOK much cleaner than the Microedge and the stock blades. It just plain looks good. I haven't driven with them yet.. =)
i'm a fan of these. I didnt; want to spend the $$, but i'm happy i did. One nice feature in snow/ice climates is that the flexible design allows you to bend the blade to clear them of the frozen stuff.
_D
2004 Forester SX
I am on my second year with my PIAA Silicone blades; they are beginning to show minor signs of aging - takes two swipes for complete clearing. I simply flipped them around to cure this problem.
I am definitely sold on SI blades; just wish I could find some for the rear window. I made my own from some SiBlades, but the quality wasn't there. Another nice thing about SI wipers is the "Rain-X effect" without using Rain-X.
We have hot summers and cold winters, with a fair amount of snow and ice; these puppies shine through it all!
Bosch Aerotwin blades-Europe
Guess what, they have a custom fitting over here that doesn't take the standard hook on the end of the wiper arm. I'm thinking about ordering the Valeos.
2004 FXT Premium 4EAT
I've been thinking about getting the Icons in the spring. I currently have Trico Innovisions (another flat blade) and they have their good days and their bad. Unfortunately, the bad days outweigh the good...so they're coming off in the spring. They also don't look as good as the Icons do.
Eh, I must say they aren't all that. Maybe I need to clean mine or something.
i got a lot of chatter with winter silblades. they have also been on the car for a year. even though they are supposed to be good for 5 years, i think they are not wiping as good as thye used to even though they seemed so-so to begin with.
hope the icons will stay on the glass so i dont have to slow down to 55 just to wipe the glass clean.
#8 Post ho
1999 Subaru Forester
Guess this will be something I'll think about doing this coming spring, my blades now like to dance all over the place
2010 dodge caravan auto
I use ones like that I love them!!
I saw some identical or very similar blades on sale for $11 at Wally-Mart the other day, but don't remember the brand.
2008 SG Model D
Just picked up a pair of icons came home and installed them...really easy and straight forward install...don't even need directions. I will post back after I have actually used them in the rain. Yes, they were pretty expensive...hope they are worth it.;-)
I usually get the micro edge excel blades...I have also used the standard micro edge and also the trico exact fit. The excels tended to be the best of the three so I stuck w/ them...and yes, until the icons came out those were the only choices at the advanceautoparts up the street.
2004 5MT XT
As an additional comment on the Icons, it's oak pollen season here in Florida, and my windshield/screen (and the rest of the car!) is covered by yellow, slightly adhesive/sticky pollen every day after I get off work. The Icons do a great job, along with copious amounts of washer spray. This is probably the worst-case scenario for wiper blades, and the Icons do a good job. The car still looks like hell despite weekly washings, but the windshield is pretty transparent, which is all I can ask for.
i cant get my silblade off of the passenger side. so i have icon vs silblade side by side.
the icons wipe a bit better but they are also newer. the diffrence is at speed. there is no diffrence in performance for the icon; the silblades go berzerk.
1 - 20 of 80 Posts
