Simple solutions are always the best. If it was rear wheel drive and wheel spin was the problem what would you do?. Wider tyres and weigh down the rear end with ballast . Ok you can only go so far with tyre width and its not so easy to add weight to the front but it can be done with lead blocks attached to the chassis . Performance wise lightness is usually king but not if tyres are spinning doing nothing.
