New 2019 forester automatic. Only 2 days since I got it. today noticed loud clicking noise when I shift from Drive to Park
Its only audible if the windows are rolled down, which is why I did not notice it earlier.
Is this normal.? have other forester owners noticed the same thing?
2019 Forester Sport CVT
I believe you are hearing the Evap system. Completely normal. You can also hear it clicking after turning off car. I’ve heard it click almost 30mins after I parked car in garage (was working in garage).
Basically, no worries.
It is click sound associated with the gear changing positions like a loud click. It doesnt sound like a electromechanical device clicking though, so I doubt its coming from evap system.
and it happens when the gear is moved from p to d to r and vice versa.
May be its normal, just do not have another similar vehicle to compare it to
2017 Forester 2.5 CVT
I hear the same noise when shifting into different gears. It's usually most pronounced on first start up. It's been doing it awhile and I forget if it came from factory that way or not... I thought it was weird too, but no problems related to transmission or shifting (yet).
I'm curious if this is normal or not, too.
2015 Forester XT Touring Stock Cooler/Heater Hardlines Deleted Custom 19 Row Cooler with -6AN Lines Directly Ported to CVT
I had the noise on my 2015 XT from the time I purchased it as a CPO with 21k miles on it. It only seemed to happen in my driveway. It didn't happen when I was parked on flat ground...
Two days old. Take it back to the dealer. Ask them to check your transmission fluid level! If they can't "reproduce" your problem...
