Forester XT exhaust system replacement
3874 Views 2 Replies 3 Participants Last post by  Benito Malito
My local mechanic showed me that my system is rusting and there is one obvious leak. I have all stock exhaust parts and was told I need to replace from the Cat. Converter and all parts back. I want to keep this great auto at least another 10 years (I only have 27,000 Miles). Should I get stainless steel parts? Also can I anyone recommend a brand of muffler, and what the entire job should cost including parts. (I am in the suburbs just outside Philadelphia)
Thanks for any advise
My local mechanic showed me that my system is rusting and there is one obvious leak. I have all stock exhaust parts and was told I need to replace from the Cat. Converter and all parts back. I want to keep this great auto at least another 10 years (I only have 27,000 Miles). Should I get stainless steel parts? Also can I anyone recommend a brand of muffler, and what the entire job should cost including parts. (I am i the suburbs just outside Philadelphia)
You have a 2005 MY vehicle, which was probably made in late 2004. It's now late 2013, so your OEM exhaust system parts lasted about 9 years. Granted, you have only driven 27,000 miles - not exactly flogging the horse.
Why not buy OEM parts? They fit properly. They are likely to last for the remaining life of the vehicle. This should be a bolt-on job so the labor bill should not be that high. If you don't want to do-it-yourself, almost any muffler shop or garage could do this.
A final thought: you plan to replace from the cat back. If, in the future, a garage suggests that your catalytic converter needs replacement, that is very expensive - prohibitively so if you buy an OEM cat. But your existing catalytic converter might be 'cleanable', assuming the housing is not rusted out. Look at this post http://www.subaruforester.org/vbulletin/f66/p0420-catalytic-citric-acid-bath-how-104347/#post1134098 or search the net for 'Citric Clean Catalytic Converter'.
Good luck on your project.
Look for stock system on Craigslist. A lot of people have aftermarket or STi catbacks and their stock system just sits in their garage.
I had the stock system sitting in my storage unit until I moved a few months back.
