2014 FXT CVT
So I've had the Forester specific STi pinks and it is very balanced between ride comfort and cornering, but ground clearance is not much better than my STi. The other day I went into play in snow and dragged under carriage a lot.
Now I'm thinking about installing both Subtle skidplate and 1" lift kit to get the ride height back to stock - does this mess with suspension geometry at all?
Also since you are taking struts off, you need an alignment correct?
2004 FXT MT Cobb Stage 2
That setup will work just fine...I believe The Wraith ran that for a while on his car. FSTi springs + a 1" lift should put you back to stock height. I considered it at one time, but I decided to go back to OEM springs with the 1" lift for the extra clearance. And yes, you should do an alignment whenever springs/struts are removed/replaced.
We have both products in stock.
I would definitely get an alignment after any suspension modification.
