Hello,
First of all I hope this is the correct place to post a rear suspension shock absorbers problem, on my Subaru Forester 2004, SG model, 2.0 non-turbo car.
My right-rear strut gone out, so I had to replace it. As usually, I liked to do it myself, so, I bought some Drapper spring compressors, quite good stuff. And I bought 2 rear struts from KYB, left and right rear, 334344 and 334345, as described on KYB site
All went OK, took some hours and changed successful.
But now, the rear part is a little lower that it was before, it just lay down few centimeters than it was originally.
I think i discovered why, i think the original absorbers had more (?) gas inside (greater pressure) and the pistons were pushed out from the strut more forcefully, this contributing to the spring, placing the rear part of the car a little higher. Now, the new struts are not so pressurized and don't take too much of the car weight, all laying on springs, right now - this must be the reason the car is now standing down with the back.
This is quite annoying, seeing the car having the front higher and the back lower, like is overloaded with weight.
Now, what to do ?
I have to say the old original struts had a lateral small cylinder near the main strut cylinder and the new ones have not. Most probably the replacement parts I have got are not identically with original ones. Too bad. Because the stuff is done, I think for a solution to lift back of the car:
- maybe stronger/longer springs ?
- maybe a lift kit for rear part ?
What to do ?
Which is your opinion ?
Any suggestion is welcomed.
Thank you
Now, what to do ?
What to do ?
Thank you
