it might be throw out bearing, it might be internally leaking slave or master cylinder. Or it might be clutch fork. mine started with a hose leak at slave. with new hose, they couldn't bleed it,and started to get noise. teardown showed throwout bearing going, with trans out, did clutch package includes clutch,pressure plate,throwout bearing,pilot bearing. they also did slave cylinder. This about 13 months ago. 2 weeks ago, having full release problem, fluid filthy. had them do bothcylinders. 2 days later felt a pop. that was clutch fork bending.
