2002 Forester S
Hey there, I was hoping for some guidance here, please -
I recently had my head gaskets replaced on my 2002 Forester. Everything seemed to be working just fine, but recently (at ~1500 miles) my oil light is turning on/flickering at lower speeds. It usually turns off when I get up to ~55 mph, but will occasionally flicker at this speed too. There aren't any other noticeable issues besides the light turning on/off intermittently.
Is my pump bad? Is it possibly a bad sensor?
Any info would be GREATLY appreciated!
Thanks in advance.
2016 and 2020 Foresters
@subgenius Assuming you checked the oil level and that's fine?
Pressure sensor or oil pump are good thoughts. I don't know the behavior of a failing sensor, whether it fails 'open' or 'closed' in terms of the signal.
Maybe a cracked oil pickup?
1999 "L" - 231,000 mi. AT
I've found on my '99 that my oil dip stick (DS) reads very high. To get a good reading I measure at gas station pulling DS out before I fill the tank and setting aside - in those 4 minutes of filling the gas tank the warm oil must drain out of the bent tube and I get an accurate oil reading (after the gas fill) that is always lower than first thing in the morning reading.
2002 Forester S
thanks for the suggestions!
turns out oil is leaking from where the sensor is attached. I'm going to purchase a new one and see if that takes care of it
I'll keep the thread updated
appreciate ya
