Status
Not open for further replies.
1 - 1 of 1 Posts
2017 Outback 3.6R Limited High Torque CVT
Here is a list of maintenance parts to keep your Forester in top shape! If you have any questions or would like me to add something else to this thread please feel free to post!
11/30/2018 - Updated!!!
Filters
Oil Filter - 15208AA12A - (EJ Series)
Oil Filter - 15208AA130 - (FB Series)
Oil Filter - 15208AA15A - (FB Series)
Oil Filter - 15208AA170 - (FA Series)
Crush Washers - 803916010 -
Crush Washers - 11126AA000 -
Subaru 0W20 Synthetic - SOA427V1310 -
Air Filters
Short - 16546AA020 -
Long - 16546AA07A -
Square - 16546AA10A -
Square - 16546AA12A -
Fuel Filters - 42072PA010 -
*Fits up to 2004, in tank filters extra!
PCV Valves
It's recommend to replace your PCV (Pressure Control Valve) about once every 30k. Not sure if your valve needs replacing? If you pull it out and shake it you should hear the ball valve knocking back and forth. If you don't hear it banging around then you know it's gummed up!
1998-2002 - 11810AA000 -
2002-2008 N/A - 11810AA040 -
2004-2008 Turbo - 11819AA001 -
2009-4/2/2009 Turbo - 11810AA040 -
2009-2010 N/A - 11810AA100 -
04/2/2009 - 2013 Turbo - 11810AA120 -
2011-2016 25B N/A - 11810AA131 -
2014-2016 20F Turbo - 11810AA141 -
Fluids
Check your "Warranty & Maintenance" booklet in your owner's information packet for your vehicle's maintenance intervals. We recommend changing your coolant along with the coolant conditioner every 30k for long life coolant users, Super coolant is good up to 107,500mi or 11 years!
Brake fluid should be refreshed or replaced every 30k unless you live in a very humid climate or at high altitude.
Complete your AWD Service with Subaru crush washers and gaskets
Coolant, Long Life - SOA868V9210 -
*For vehicles up to 2009, non mixed.
Coolant, Super - SOA868V9270 -
*For vehicles 2009+, pre-mixed.
Coolant Conditioner - SOA635071 -
Brake Fluid - SOA868V9221 -
ATF/PS HP Fluid - SOA427V1500 -
*For vehicles 2006 and up.
Subaru HP Gear Oil, 75W90 - SOA427V1700 -
Subaru LSD Oil, 80W90 -
Additives
Over time your heating and cooling system can get develop odors that are unpleasant. Use an A/C refresher kit to clean out the ducts and breathe easy! Think of it like a "Draino" for your duct system, it foams up and runs out cleaning the walls of the ducts and removing odors in the system. Try this kit along with a new pollen filter!
A/C Refresher Kit - SOA868V9315 -
*Includes evaporator foam, intake spray and tube for use.
Subaru offers an engine maintenance kit to keep your Subaru in top shape. Is your throttle response a little sluggish? Reduced gas mileage? Your engine works more efficiently when it's moving parts are moving free and easy!
Subaru Engine Maintenance Kit -
*Includes top engine clean (tool required), throttle clean and fuel additive.
Spark Plugs, Ignition Wires, Coil Packs, Knock Sensors
1998 Platinum Plugs - 22401AA570 -
1999-2004 Copper Plugs - 22401AA310 -
2005-2010 N/A Platinum Plugs - 22401AA65A -
2004-2008 Turbo Iridium Plugs - 22401AA630 -
2011-2016 25B N/A Plugs - 22401AA781 -
2009-2013 Turbo Iridium Plugs - 22401AA670 -
2014-2016 Turbo Iridium Plugs - 22401AA830 -
1998 Ignition Wire Set - SOA430Q121 -
1999-2004 N/A Ignition Wire Set - SOA430Q119 -
2005-2008 N/A Ignition Wire Set - SOA430Q124 -
2004-2008 Turbo Individual Coil Packs - 22433AA542 -
1998 Coil Pack - 22433AA370 -
1999-2004 N/A Coil Pack - 22433AA570 -
2005 - 2008 N/A Coil Pack - 22433AA580 -
1998 Knock Sensor - 22060AA061 -
1999-2002 Knock Sensor - 22060AA070
2003-2004 N/A Knock Sensor - 22060AA100-
2004-2005 Turbo Knock Sensor - 22060AA111
2006-2008 Knock Sensor - 22060AA140 -
Drive Belts
Inspect your drive belts regularly for cracks and signs of wear or fraying. A broken drive belt can easily take out associated parts in it's path. Subaru recommends inspecting your drive belts every 30k and replacing at 105k however we often find the need to replace them around 60k-70k.
1998-2006 A/C Belt - 73323AC000 -
11/2007 - 2008 A/C Belt - 73323SA000 -
1998-2002 Alternator Belt - 809218270 -
2003-2005 Alternator Belt - 809218450 -
2006 Alternator Belt - 809218370
2007-2008 N/A Alternator Belt - 809218370
2007-2008 Turbo Alternator Belt - 809218450 -
Stretch Belt Set - 11718AA082
*Sold with tool kit.
Cabin Filters
1998-2000 Filter Kit - G3210FC000 -
2001-2002 Filter Kit - G3210FC200
2003-2008 Filter Kit - 72880SA000 -
2009+ Cabin Filter - 72880FG000 -
Remanufactured Parts - Non-Turbo Only!
1998-2000 Front Axle Shaft - SOA966H900R1 -
2001-2002 Front Axle Shaft - SOA966H1100R1 -
2003-2006 Front Axle Shaft - SOA966H1200R1
2009-2013 Front Axle Shaft - SOA966H1500R1 -
5/97-2/02 M/T Starter - 23300AA380R1 -
5-97-2/02 A/T Starter - 23300AA390R1 -
1998 Alternator - 23700AA290R1 -
7/98-2/02 Alternator - 23700AA390R1 -
Wheel Bearings
1998-2002 Front Wheel Bearing Kit -
*Includes bearing, two seals and axle nut.
-28016AA011NT -
-28015AA070 -
-28015AA080 -
-28044AA001 -
1998-2002 Rear Wheel Bearing Kit -
*Includes bearing, three seals and axle nut.
-28016AA030 -
-28015AA090 -
-28015AA100 -
-28015AA110 -
-28044AA001 -
2003-2008 Front Wheel Bearing Kit -
-28316FE000 -
-28015AA070 -
-28015AA080 -
-902170049 -
2003-2008 Rear Wheel Bearing Kit -
-28016AA030 -
-28015AA090 -
-28015AA100 -
-28015AA110 -
-902170049 -
Disclaimer: Although every effort has been made to avoid errors on the parts listed above, part catalogs are not perfect and neither am I! To make sure that you get the right parts always best to supply a VIN so that fitment cab be checked.
Thanks,
Jackie
1 - 1 of 1 Posts
Status
