Okay, I'm not just a Forester Dummy...I'm a auto idiot!! I've been studying but I wanted to bounce a few questions off of some experts so let me fill you in on what's going on right this minute...
1. Routine check discovered coolant in the oil/head gasket needs to be replaced
2. New timing belt needed
3. Check engine light on with Cruise light blinking
4. Transmission service needed
Here are my questions -
1. Should I just have the timing belt done when the head gasket gets replaced? What else should I have fixed while they're in there? I read something about tensioners, idlers, water pump, thermostat, all seals including cam and crank and pulleys...is that about it or am I missing something? What about an oil pump o-ring? Is transmission service included with any of this? New coolant?
2. Do I have a serpentine belt on my 2005 Subaru Forester X? Should it be replaced as well? I need a full tune-up...is this included and will this change belts and hoses? What about pcv valve, plugs and wires, air filter, cabin filter, fuel filter, distributor cap and rotor, ac system and cooling system? What about a rear diff fluid change?
3. I've been told something about my CV Boots/Joints...I read that it's cheaper to just replace the entire axle. True and will I need all four??
4. Check engine light...cat converter or oxygen sensors? This is totally foreign to me!!
I apologize for all the questions but I'm just trying to go in without being completely in the dark on what's needed so please, if I left something out, let me know. I've put aside a chunk of money for car stuff so I want to take care of everything possible asap. Thanks!!
Stephanie
105,000 miles
Stephanie
105,000 miles
