2011 Forester 2.5x Premium
Is there a rear seatback protector available for thos model or just the cargo tray? How different were the newer models, could I just mod a newer cargo tray and rear seatback protector?
Also, is there a hitch mounted accessory that would work for both bicycles and a 150lb scooter?
· Premium Member
2011 Forester X Premium AT
There isn't an OEM seatback protector available until the 2014 model. No idea if the newer version would work on a 2011 as the interior dimensions are slightly different, but it could be worth doing a test fit if someone will let you try it out. I made my own rear seatback protector after seeing one on this site, and it works pretty well.
Hmmm, I might see what the difference with the 2014 ones are. If they are a little undersized not sure I'd mind. And oversized I could just cut maybe.
2015 Forester 2.5 Premium CVT
If you do go that route, I'd like to see a picture of what you end up with, if possible. Just curious...
Mike
