1 - 20 of 58 Posts
2007 APS DR65, FMIC, UTEC 6MT from Forester STI (JDM)
Forester 07MY 2.5T 6MT UTEC Darton APS FMIC (Oleg B)
Hi all,
Regards from Ukrainian Forester Club (www.forester-club.com.ua).
Short description of my car Forester 07MY 2.5T:
1. Power (engine, turbo, intake, intercooling, exaust, etc.):
1.0. Engine:
1.0.1. Darton Dry sleeves 300-031-3
1.0.2. O-rings (cylinder heads)
1.0.3. JE pistons (standard 99.5mm, JE 291061)
1.0.4. Cryo Treated Crankshaft 12200AA330
1.0.5. Manley H beam rods 14024-4
1.0.6. ACL Main Bearings 5M8309H-STD
1.0.7. ACL Rod Bearings 4B8296H-STD
1.0.8. ARP Head Studs 260-4701
1.0.9. 1000cc Injector Dynamics Top feed (1000.18.03.48.11.4)
1.0.10. Oilpump 11 ìì (custom ported) 15010AA360
1.0.11. TGV deleted
1.0.12. Gates Extreme timing belt kit TCK328RB
1.0.13. Genuine Subaru Head Gaskets 1.5 mm (11044AA610)
1.0.14. Engine Gasket and Seal Kit Subaru 10105AB010
1.0.15. Cold Air intake APS (APSWRX-HFA/01 - 65mm) + filter K&N (RU-3130 )+ K&N DryCharger Air Filter Wrap(RU-3130DK).
1.1. Turbo Greddy TD05-20G
Previous setup:
1.1.Turbo VF-48 (STI 2008+)
1.2. TurboXS UTEC Delta ECU (with map selector)
1.3. Intercooler STI GRB 2008+
1.4. Tall hood scoop STI 2002 (EDM)
1.5. Custom splitter
1.6. APS 3" Turboback
1.7. HKS EVC6 Boostcontroller
1.8. Fuel pump Walbro 255 ë/÷
1.9. Protuned by Bilyk WRX
2. Electric:
2.1.Head Up Display DEFI Display VSD Concept with all sensors connected:
- EGT
- Oil temp
- Water temp
- Oil press
- Fuel press
2.2. AEM UEGO AFR Gauge
2.3. Genuine Subaru Engine Heater (cylinder block)
3. Oil cooling:
3.1. Oil Cooler set TRUST/Greddy with thermostat
3.2. STI heat exchanger
4. Transmission:
4.1. 6MT Forester STI (JDM) with longest Subaru gears
Previous setup:
4.1. 6MT STI-04 (EDM)
4.1.1. R180 Rear diff (3.9 final drive)
4.1.2. Rear STI knuckles 5 x 100
4.1.3. Rear STI axles
4.2. Short-throw shifter 6MT (custom)
4.3. Front shifter bushings 6ÌÒ (Torque Solution)
4.4. Rear shifter bushing (Kartboy)
5. Steering:
5.1. Steering rack STI 04 (2.7 lock-to-lock)
5.2. Steering rack bushings Whiteline
6.Brakes:
6.1. Brembo Gold
6.1.1. DBA 4000 Series T3 Brake disks slotted (front/rear)
6.1.2. Ferodo DS2500 Brake pads
Previous setup:
6.1. Big Brake Kit JBT (front/rear):
-Front 4-pot JBT + 2-piece JBT slotted disks 330 õ 30 mm
-Rear 2-pot JBT + rear vented JBT disks 290 õ 20 mm
-Ferodo DS2500 Brake pads
6.2. Brake Master Cylinder stopper (Cusco)
7. Suspension and Handling:
7.1. 4-way adjustable struts (made by STI for Forester XT).
7.1.1. STI Pink Springs for Forester XT
7.1.2. Genuine Subaru GroupN tophats (front/rear)
Previous setup:
7.1. BC Racing coilovers
7.2. Front Sway Bar Cusco 23 mm
7.3. Front endlinks Kartboy
7.4. Rear Sway Bar Cusco 22 mm
7.4.2. Rear endlinks Kartboy
7.6. Sway bar mounting brackets (STI 04)
7.7. Aluminum Lateral Links (from JDM Forester STI) with all new GroupN bushings
7.8. Rear Trailing Arm with GroupN bushings (front/rear)
7.9. Aluminum Front Control Arms (from JDM Forester STI).
8. Strut Bars, braces, etc.
8.1. Hardrace Engine and transmission Mounts Set
8.2. Front Strut Tower Bar Kakumei
8.3. Rear 5-points "mini-cage" (custom)
8.4. H-brace Cusco
8.5. Fender Braces (custom)
8.6. Kartboy Transmission Cross Member Bushings
8.7. Rear Diff Outrigger Bushings (custom)
8.8. Rear Subframe Bolts (custom)
9. Computer stuff and music:
9.1. 2DIN Gauge pod with ASUS Nexus 7 3G Tablet installed (internet, OBDII, GPS)
Previous setup:
9.1. 2DIN CarPC Revosys 500 (monoblock)
9.1.1 OBDII ELM 327 Bluetooth
9.1.3. USB Hub 7 ports D-Link DUB-H7
9.1.4. Rear view Camera Sony CCD
9.2. Kenwood DNX 7240BT (stock location)
9.2.1. Audio Systems Speakers
10. Interior:
10.1. RECARO STI GRB Seats with airbags
Previous setup:
10.1. STI 07 Limited seats (with airbags and heating)
10.2. Steering wheel (alcantara)
10.3. Carbon fiber interior styling
10.4. Leather Instrument panel and hand-brake boot
10.5. STi Pedal Pad Set Forester 2006-2008 M/T
11. Exterior:
11.1. Genuine Subaru aerokit (EDM) - Carbon-fiber style
11.2. Front Grille Forester STI JDM
11.3. Foliatech film (Carbon Fiber Styling)
11.4. Black Headlights
11.5. Black Tail Lights
11.6. STI 07 Diffuser (custom installation)
12. Wheels
Summer: RAYS Engineering VOLK Racing GT-C (2-piece) 18"x8" ÅÒ42 (Black custom powdercoated)
Previous setup:
Summer: RAYS Engineering VOLK Racing SE-37A 18"x7.5" ET48 Gold (Forged Monoblock) - 7.5 kg
Winter: Forged monoblock AG wheels 17"x7" ET48
13. Consumables:
Redline 5W50, Redline Lightweight Shockproof (rear diff), Motul Inugel Expert Ultra Coolant, Motul RBF 600 Brake Fluid
14. Useless things:
14.1. Radiator cooling plate (custom)
14.2. Hood dampers
14.3. Silicon hose set (blue) - 25 ea.
15. Different photos (link)
16. Different videos (link)
17. Second Forester 2.5T 2007MY 4AT Black JDM style (wife's)(link)
18. Third Forester 2.5T 2007MY 4AT (Champagne Gold Opal) (wife's) (link)
Lucas
2004 Forester XT Manual
привет Oleg! Привет из Польши!:laugh:
I forget Russian a bit, so apologize if I missed spell anything! You have two exceptional Forester! Could you show a picture of your rear diff custom installation please!
Discussion Starter #16
Hi, your Russian is still perfect.
Regarding "8.7. Rear Diff Outrigger Bushings (custom)": bushings themselves are made custom from polyurethane (Shore 65), sizes were taken from Whiteline items (Shore 75). If you need exact sizes - PM me your e-mail, I'll send you sizes.
Installation is straight forward, according to Peaty's instructions at ScoobyMods (need registration to view pictures):
Kartboy Rear Diff / Cross-Member bushings
Discussion Starter #18
Before I had seats from STI 07 Limited (with airbags and heating, recovered with black perforated leather + blue perforated alcantara) - you can see them on pictures, thbut they were too wide for me on racetrack.
Now I have RECARO GRB STI 08+ seats (some welding required to install in SG Forester)- they are amazing!!!
My wife's beige seats are from some STI GDB with airbags (recovered beige leather + alcantara)
1 - 20 of 58 Posts
