1 - 11 of 11 Posts
2015 Forester 2.5 Manual
Hey guy, long time reader first time poster. So much good info on here! I have a 2015 forester 2.5 m/t. I got all the parts to do the OEM fog light install. All wires are there from the factory, plugged lights in, switch in, relay in. Really simple except when i push the button ... NO LIGHTS! I cant hear the relay click when i push the button. Button lights up when i turn the headlight switch to the marker light setting. I bench tested the bulbs and they are good. Has anyone run into this issue? Am i missing something? Any help is greatly appreciated.
· Administrator
2016 & 2018 2.5i Premium CVT
'Illumination' light in the switch is independent of foglight circuitry. Do you see the brighter ON light in your tests?
Foglights only work when headlights are on and in low beam. Have you tested in that condition?
You didn't mention fuse. What does owners manual say about that?
· Administrator
Per wiring diagram, it's powered from Fuse 29 in the footwell fuse block. Switched on positive side by relay. Relay triggered from BIU, the internal logic of which is of course incomprehensible.
Diagram attached.
2011 Forester 2.5X Automatic
Any chance there's a fuse for this circuit that, since it wasn't installed at the factory, isn't there?
The lamp circuit probably uses a control circuit to power the relay. While all you have to deal with is 12vdc this control circuit draws lots less current and therefore doesn't require some super heavy duty switch to turn the lamps on. That heavy duty switch is the relay. A low amp circuit is used to energize the relay (essentially a heavy duty switch) and the high current is passed through the relay to from the high amperage fuse box in the engine compartment which is usually connected directly to the battery.
Check for a missing fuse in the under dash fuse panel.
· Administrator
If fuse 29 is dedicated to fogs, and I would expect that it would be due to the wattage of the bulbs, then it most probably wouldn't be installed if the car wasn't equipped with fogs.
The relay is controlled by the BIU, Body Integrated Unit, a multi-purpose module that controls most everything.
As for requiring low beams (and only low beams), it has been that way since my 2003, and probably forever. In the US anyway. In some places it's a legal requirement.
1 - 11 of 11 Posts
