Does anyone know the torque ft. lbs on the 2001forester flywheel manual?...on the crankshaft bolts and the bolts on the back of the flywheel that holds that thin plate to the flywheel.
Thanks,
Roger
2004 Forester 4EAT
pressure plate to flywheel-11.6 ftlbs
flywheel to crankshaft- 53 ftlbs
the last one you listed ? No pics of it in haynes manual.
It says to tighten in crisscross pattern and use locktight.
beat me to it:evilatyou: :biggrin:
04 Forester X, MT
before putting the flywheel back on, did you first be sure the oil separator plate was metal instead of plastic?
2017 VW Golf SportWagen 5MT
Wow, I'm surprised at how low the torque value is for the flywheel to crankshaft bolt.
Stan
