Hello,
my 07 X is at 57k, and I am wondering if it is okay to use a hand pumped fluid extractor instead of draining from the bottom. I plan to do the drain/fill/repeat process, that others have written about here.
The extractor has a graduated fluid chamber, so it will be easy to measure the amount of fluid removed.
Also, if done this way, would adding new synthetic ATF each time be a bad idea?
Thanks!
Thanks!
