Hello,
I have 2012 Forester that was in a minor front end accident. It didn't get damaged too bad, mostly just the front bumper and right fender. However the drivers and passengers airbags were deployed..
I have installed -
- Both front airbags (that passenger side is a pain as the whole dash has to get replaced)
- Both Front crash sensors up by the bumper
- front seatbelts
- Srs Module sent out and hard codes cleared
Would there be anything else that would need replacing?
Thank you
1998 Forester
I'll try to remember to research this tomorrow. The manual has a list of mandatory items.. one I recall is the clock spring
Sent from my SAMSUNG-SM-G935A using Tapatalk
I did do the seat belt pretensions.. Found a place called Safety Restore that fixes them.. I did not replace the clock spring yet, I just attached new wires to the original clock spring. I will replace it if I need to.. As you probably know, those connector melt into the back of the air bag when it deploys..Thank you
