Upgraded to Carbotech Bobcat pads all around, Goodridge SS brake lines all around, H6 rear disc upgrade, Mutol RBF600 fluid.
The weak link are now the tires for braking. I pushed down firmly on the pedal from 60mph and was able to squeal the tires!!! Maybe I'll update after more miles on this setup. I just did about 10 60-30 stops and parked the car.
Thanks Roo for overnighting me the clips I needed to put in the rear brake pads!
No noise from the Bobcats. I did develop a nasty noise during my first bedding run from the rear but it turned out to be the dustshield rubbing the rotor. A crowbar and hammer fixed that. =)
The speedo needle is drops very quickly when giving medium braking pressure now!
