1 - 10 of 10 Posts
04 FSTi Manual
My temperature gauge is bouncy around like a Spaniards honeymoon mattress at the moment, it will literally go from normal (just under halfway) to beyond the red and back down to normal in the space of a minute.
I had a similar problem in my Escort and I eventually worked out that the thermostat needed replacing.
Same thing on the foz do you think? Also, would you risk leaving it til the weekend (i *should* only need it tomorrow but that may change) or is it best to get it sorted right away?
2003 XS
As suspect as Subaru's head gaskets are, I would not tempt fate and drive the car with a malfunctioning cooling system. Overheating is going to stress both the head and the head gaskets possibly causing them to fail and/or warp. I would get your problem checked out asap. Changing the thermostat is not a difficult task for a DIYer if that is what's causing your problem.
99 UK S-turbo
Stat is a doddle on the EJ engines......
Maybe of course a slightly poor connection on the temp sensor, they work of resistance and a small change can have a big effect.
Simon
JDM Foz [sold]
2016 Mercedes E220 AMG Auto
check water levels first.
Mine went up on Saturday and I though damn burst my rad when I hit a snow bank. Checked the water level and it was down, so topped up with the engine running and its been fine since and coolant level hasnt gone down.
1998 Forester automatic
thanks for the info in this thread! i am pretty sure i have the same issue in my 98. middle...up to red, hovers for a minute, back down to middle. never to bottom, but always between middle and red. will check coolant first.
1 - 10 of 10 Posts
