1 - 20 of 30 Posts
Driving across Kansas and the wind was blowing its normal 30+ mph and a tumbleweed came acrooss the road and the brakes started to lock up and about the same time it passed the front of the car. The brakes were only locked for a half second and then they released. Be aware.
2019 Forester Sport Lineartronic® CVT
Wow, never imagined a simple ball of dried up grass / weed causing that. I guess, same with a deer or bear or cow crossing road suddenly. Hope not squirrels!
2019 Forester Sport
The eyesight locked up on me as I was in a semi slow traffic but it was still flowing. My lane was on the slower end, as a big rig goes pass me I switched lanes just right behind the rig. I was barely stepping on the gas pedal. As I fully switched over the eyesight locked up the brakes on me. To me it seemed a little dangerous as the car almost made a full stop with cars moving.
2019 Forester
Eyesight isn't really ready and could use a lot of improvements in my opinion, but it's still worth it because it can save a life.
I'm looking forward to truly autonomous driving. I'm really upset that every manufacturer is trying their own thing. It's way too dangerous. I'd rather see everyone get on board with Waymo, rather than just Jaguar Land Rover. I'm assuming it's all about the money, and it's more profitable for each company to make their own system. It's just people are dying in the meantime.
2013/14 2.5i-L CVT
So Eyesight was suddenly presented with a large object right in front of it and the distance closing? Was adaptive cruise control activated?
Had you taken action by accelerating Eyesight would have reset. As per the Eyesight manual, braking, or turning the steering wheel also works.
Yup. It happened to me with a plastic bag blowing out of the truck in front of me. I was able to convince Fozzy that I got this by hitting the accelerator.
It also happened to me at low speed when I was parking with a low hanging tree branch where I wanted to park.
It was a little surprising, but your "Be Aware" advice is right. All in all, I'm glad it's there and think it will move the needle on safety in the right direction.
2012 Forester X Auto
The problem is unintended consequences when the system is working as designed.
Had the tumbleweed been moving straight at the car, instead of across the lane, Eyesight would have likely interpreted this as an impending head on collision and stopped the car. With its machine reflexes, that happens pretty fast.
Is the semi-truck behind you capable of suddenly stopping for no reason? Probably not.
Eyesight does not "know" what any object is, and in the case that @titleman noted, a non-problem (tumbleweed) could result in a major problem (being rear-ended by the vehicle behind you because your car decided to slam on the brakes). That's the safety tradeoff.
I'm convinced there will be lawsuits against Subaru for cars designed to stop more quickly that a human following the car can, especially when there is no reason for the Subaru to brake in the first place, as would be the case the OP mentioned.
Maybe turning off the system on a windy day is a good idea in tumbleweed country.
2019 Forester Sport
Cruise crontrol was not activated. Either way it may or may not be my fault for switching lane that close behind a big rig. Eyesight worked for what it was designed for.
In the initial moment it happened, it was more like a oh ***** moment. I think I tried to step on the accelerator trying to prevent someone from rear ending me.
People just need to get less rushed, learn what a proper following distance is and actually drive the car.
It did so likely "interpreting" the new target as too close. It suddenly "realized" that you were too close at that speed, so it applied brakes.
Something happened with ours that was a bit uncomfortable too, I was following NOTHING, cruise set at speed limit, car was too close behind me and another car passed me and cut in pretty close to my front, Eyesight reacted by slowing car, I hit the gas as I just "knew" what was gonna happen, car behind me also passed & got the hell on up the road after that. Lesson learned again ...I had to drive for those two clowns too. :surprise:
2016 Forester CVT
The auto brake function is one feature of the eyesight system that I strongly dislike. It often wants to brake when someone is turning in front of me. Has anyone discovered a simple way to permanently disable it, like pulling a fuse?
That's hard to argue with... but does a proper distance include enough room to account for an unnecessary panic stop on the freeway?
If your car on the interstate is doing 75 or 80, and it decides to slam on the brakes because of something like a tumbleweed or a plastic bag, the chances are there is going to be a collision. Ordinarily, people don't make irrational panic stops at high speed, but an automated system will.
Hopefully it won't be a semi-truck with a full load behind you, but it could be, and that is part of the unintended consequences of a "safety" feature.
Air bags are another example..
Although originally intended to assist in prevention of injury from someone who isn't wearing a seatbelt, they have also caused deaths in situations where an occupant would have survived without them.
In both cases, likely the positive outweighs the negatives in the majority of cases, but in any specific circumstance, your results might vary.
Based on forum feedback, I leave a lot of extra distance when following a late model Subaru and pass at the first opportunity.
It's windy very often here and you never know when a "killer plastic bag" may be coming your way...
:wink2:
There's a button by the rear view mirror to turn this off. Correct me if I'm wrong but I think it will remain off until long pressed again even after a restart. I haven't tested to see if it remembers "off" after a restart.
2016 Forester CVT
From the manual:
"Even when the Pre-Collision Braking System is turned off, if the ignition switch is turned off and the engine is then restarted, the Pre-Collision Braking System will be turned on."
2019 Forester base Auto
You know what I hate is when someone cuts you off really bad , and the precollision system activates to slow you down , makes me pretty upset ! I want to call them names ! 😯🤬
2017 Forester XT Premium CVT
Yes, that is what the system is for and it's a good example of it working as intended as a safety feature. Just like in the commercial, where the dad takes his eyes of the road for a second and eyesight stops him from hitting the log truck, or golden retriever, or whatever. Well done Subaru, insurance companies rejoice!
But what about when you are driving down the highway and everyone is bumper to bumper doing 75mph (legal on PA turnpike and typical rush hour around Philly).... and a plastic bag (or tumbleweed) makes your car slow down suddenly? And the dump truck 2 car lengths behind is now in your back seat where your baby used to be? Then you'll be suing Subaru and calling them the Devil.
The more I read about Eyesight here on the forum, the more glad I am that I didn't get it.
How is such gross stupidity Subaru's fault?
Oh, people driving the speed limit in a grossly overpopulated urban environment is not Subaru's fault. But if a car travelling in pace with traffic suddenly slams on the brakes, by it's OWN decision, while it's competent driver is watching traffic and responding like a good driver should....
Then your car has gone homicidal like a bad sci-fi movie. Remember about 10 years ago when Toyota Prius's started accelerating and at the same time having complete brake failure? You know, the one where the smart technology killed and maimed people to the tune of 1.1 Billion dollars in lawsuit settlements? Yeah, bad sci-fi movie time, tech nerds.
I think the only thing I might need Eyesight to protect me from is other Subarus with Eyesight. My wife is on the Tesla kick because she is a tech geek and would wet her pants if she had a car that could drive her like an uber, while she works on her laptop oblivious to traffic.
I don't like that future. Not yet anyway. I prefer cars with manual transmissions and manual roll down windows, and I often take out the working AC components.
Automated cars, in 2019, only work if the human variable is removed from the equation. You know, free will and all. Who needs that? Pfft.
1 - 20 of 30 Posts
