Hi everyone.
I am interested in getting a Subaru with dual range transmission. I see models as late as 2018 with petrol engine manual transmissions. Are these all dual range? It sems they out of production, so wondering which EU models had dual range and how to id them. Thanks
2009 Forester 2.0 XS
AFAIK all N/A Subarus in Greece (and maybe middle east, Russia, Ukraine, Europe?) had dual mode. My old impreza had it. My current 2009 Forester 2.0 XS has it.
I find it convenient sometimes. E.g. when there is a steep uphill , or if you drive on slippery ice or sand, or you need more torque. IIRC also some suzuki's had it. Don't know why they are dropping it. It was a unique feature.
SPECIFICATION
1. MANUAL TRANSMISSION AND DIFFERENTIAL
Model​
2.0 L DOHC​
2.5 L SOHC​
2.5 L DOHC turbo​
Type​
5-forward speeds with synchromesh and 1-reverse
5 × 2-forward speeds with synchromesh and 2-reverse *1​
Transmission gear ratio​
1st​
3.454​
2nd​
2.062​
1.947​
3rd​
1.448​
1.366​
4th​
1.088​
0.972​
5th​
0.871​
0.780​
0.738​
Reverse​
3.333​
Auxiliary transmission gear ratio *2​
High​
1.000​
Low​
1.447​
1.196​
Front reduction gear​
Final​
Type of gear​
Hypoid​
Gear ratio​
4.111​
4.444​
Rear reduction gear​
Transfer​
Type of gear​
Helical​
Gear ratio​
1.000​
Final​
Type of gear​
Hypoid​
Gear ratio​
4.111​
4.444​
Front differential​
Type and number of gear​
Straight bevel gear (Bevel pinion: 2, Bevel gear: 2)​
Center differential​
Straight bevel gear (Bevel pinion: 2, bevel gear: 2 and viscous coupling)​
Transmission gear oil​
GL-5​
Transmission gear oil capacity​
4.0 L (4.2 US qt, 3.5 Imp qt) *2​
3.5 L (3.7 US qt, 3.1 Imp qt)
*1: Dual-range model
From what it writes In mine I think the "Lo" range is 1/1.447 of the "Hi". In 2.5 models it is 1/1.196 (or at least this is my understanding)
