1 - 2 of 2 Posts
2003 Forrester S Turbo
Hi everyone,
I was driving home today when the engine management light came on. It is just a solid light and not flickering. Are there any common causes? Also is there a place in Birmingham that can check the diagnostics? A lot of the main places are charging £50 which seems a bit steep to me!
MY11 WRX STi Sedan 6MT
Hi everyone,
The code list is as long as your arm so it could be anything.
In your profile you show a 2003 S Turbo :confused:
If that's a late registered MY02 SF5 S turbo then its OBD compliant so you can buy your own code reader to read codes. :biggrin:
An example........
Diagnostic Scanner CAN Code Reader OBD2 EOBD II MS300 on eBay (end time 10-Jun-10 14:43:37 BST)
List of codes available in this section of the manual.....
http://66.196.80.202/babelfish/tran...p://www.subaru-car.ru/for1/for_01_sec2_12.pdf
1 - 2 of 2 Posts
