2001 Forester
Hello
My wife has a Subaru Forester (2001) petrol engine (2.0).
The engine management light has come indicating something is wrong. The car is now running like a dog, and drinks petrol.
Last time this was traced to a sensor ( catalyst sensor ?) and required its replacement (the sensor) and a heat shiled re-welding in place. This cost me nearly 400 pounds, ( I was away on business at the time, so couldn't do anything).
Is there a fault diagnosis process for fault finding engine management problems in Forestors ? If it requires welding, then thats something I can't do, but replacing engine sensors I can do.
Cheers
· Don, King of the parts diagram
MY11 WRX STi Sedan 6MT
If you come back to the Forum pop over to the Europe forum, plenty of info, help and answers there.
· Premium Member
2004 Forester 4EAT
Possible front O2 sensor. Have a shop pull codes for you. On the other side of the pond, most parts stores will tell you the codes for free.:raspberry:
99 UK S-turbo
You need the fault codes.....a generic OBD code reader will tell you the code then we can help!
There is no such thing as a catalyst sensor, Exhaust gas temperature or Oxygen sensors are both in the exhaust but neither should have cost £400!
Simon
