All installed! It sits a little low, but I haven't really had time to sort out preload and damping.
I'm going to drive it as-is for a month or so to let things settle, then I'll adjust preload and ride height when I go to swap out the rear bump stops.
My alignment is spot on. -1 degree of camber all around, 0 toe in the rear, +0.01 on the front, and 7.5 degrees of caster on the LF and 6.8 degrees on the LR. The caster is the result of swapping the camber plates left-to-right, and rotating them so they kick in-and-back. Spring rates are mild. 7k front, 8k rear. Nicely balanced. Once I tune it, I may decide to swap from 7k fronts and 8k rears to 6k fronts and 7k rears.
It needs some tuning, but the initial impressions are pretty good. I'll probably spend an entire day tuning in the next few weeks, but the first thing I have to do is swap out the rear bump stops and maybe get something to help adjust camber in the rear.
For the money (I think the FXT specific ones are in the $1400 range?), they can't be beat. The quality is astounding, and the ride is spot on for a daily driver (since they were, afterall, designed around daily-driving). They are also about 3/4 the weight of the stock stuff, which is nice.
I still haven't had the time to take measurements and model the suspension in 3D, but I think I have the ride height set alright. I'm at 15" front and rear from hub to fender, just about 2" less than stock. I'm not entirely sold on the ride height, I still feel like it's a little low. I'll sort all of that out when I go to tune the setup though, then I'll re-align the car and button everything up.
Pics tomorrow if it's sunny!
