I installed the an aftermarket timing belt on my EJ25 Engine, but I can't seem to get the white line markings on the belt to line up with the blue dots on the drivers side sprocket. The white line will only line up on either side of the blue dot. See image below.
I believe the important thing is for the output gear marking to be aligned with case split and that the blue dots on the cam sprockets are aligned with the marking on the case. So, I thats how I set it up.. I even rotated the engine several times to make sure there is no internal interference and that the blue dots come back and line up correctly with the case markings..
Is this correct? Anybody have any insight before I put the engine back in and try to start her up?
I think my situation is similar to the guy in this post: http://www.subaruforester.org/vbulletin/f66/timing-belt-pump-change-14416/index4.html. He aligned his drivers side sprocket to the white dot on the sprocket, not the blue dot or the white line on the belt..
