Tried to reset my ecu last night to see if I could get this new maf sensor to work. Left the battery disconnected for about 2 hours. I had unplugged the old maf with the ignition on as to throw up an error code to see if that would also clear.
Once I started it I still had the error code and left it running for about 10 minutes it was pretty rough and the revs kept dropping and rising. Though it was just adjusting to the new maf. Anyhoo, switched off the engine and it just stalled right away again, put the old one back in and it was fine again
Had I reset the ecu? Also should I just wait for the engine to warm up and drive off without switching it off?
Will 5 hours be long enough to reset the ecu? I have disconnected the batt and swapped the new maf back in. Will try during lunch or wait till after work which will be over 8 hours.
