1 - 8 of 8 Posts
none none
Do you have a resistor in the EGT harness? If you have a catless uppipe you'll probably need one unless you had them turn that CEL off in the tune.
2005 Base 2.5x foz
that, if you removed the EGT sensor (and you probably should) all you need to do is stick the right resistor in the plug and tape it up.
2005 Forester XT
ok thanks, that makes sense. Until I get a chance to take care of that, is it ok to drive though?
2004 Subaru FXT MT
The EGT values will change the AFR targets a bit. You should be perfectly fine, but you could monitor your AFR's with you AP in the mean time for peace of mind.
I'd have to double check, but I would think that with high EGT's, the ECU would respond by running more rich.
1 - 8 of 8 Posts
