In preparation for removing the engine from my wrecked '04 FXT to transplant it into a new vehicle, I've been scoping out all of the critical timings and voltages on the motor as I'm still a bit on the fence as to whether I'll be retaining the stock ECU or going with a Megasquirt. That thread is here.
So a couple of days ago, I went in to establish the timing relationship between the crankwheel and the #1 ignition coil. Here's the scope trace I took of that measurement, at idle, with CKP in trace #1 and IGN 1 trigger in trace #2:
Note the timescale: 10ms/div. Which means that the dwell was approximately 8ms.
Needless to say, this struck me as quite odd. I'm much more accustomed to seeing dwell measurements in the 2.5-3ms range on modern COP ignition systems.
Last night, I measured it again, this time with a DC current probe as well, clamped to the +12 supply to the coil. Trace #2 is the current probe, which is scaled to 10mV=1A, and the scope vertical is 20mV/div. Timescale here is 1ms/div. Trace #1 is the trigger to the coil:
Ooooooo-kay. Now, at idle, I'm seeing about 4.8ms, which is more reasonable, but still a lot longer than I'd have expected, particularly given that the coil is clearly self-limiting at 9A after just under 3ms.
Searching around here hasn't turned up much on the subject of dwell, though a bit of googling produced links to a few other sites where times in the 2-3ms range were being tossed about. I've been poring through RomRaider, and I can't find any obvious table which specifies dwell settings.
I will add as an aside, that I've been leaving the battery on this vehicle disconnected except when I'm actively working on it, and that these measurements were taken after periods of running ranging from seconds to tens of minutes. I can't imagine that the ECU has any sort of auto-learning feature for coil dwell- can it? There's no feedback mechanism that I can see.
Does anybody have any thoughts on the matter which they'd care to share? This isn't exactly a show-stopper, but it's damned curious and I'd really like to understand whatever phenomenon I'm seeing here.
