1 - 7 of 7 Posts
45,000 KM 2007 XT (about 30,000 miles). 3 years old. Always in a tropical hot environment that has killed many wheel bearings on my previous cars.
I have a dull whine in the back at 80km/50 mph or more... it doesn't change pitch with acceleration. I think it's a wheel bearing (I can't decide which side) but it might be a diff issue. Is there any way to tell?
2000 forester turbo s
hello!
Hi there,
Sounds to me like a wheel bearing,mine did the same,usually jack up the car and check for any play by holding the wheel and wobbling from side to side,though there was no play in mine i noticed the noise got louder on right hand bends as the weight of the car shifted,pointing me to the left hand bearing.Very unusual for a diff bearing to go,they are pretty much bullet proof!
1999 Forester
If there's play in any of your wheels, you're on the verge of catastrophic failure.
Here's a good way to check:
With all four corners off the ground, spin the suspect wheel while placing your other hand on the coil spring. Any roughness in the bearing will be transmitted and felt through the coil spring.
1 - 7 of 7 Posts
