Hi all, I have recently bought a 99 forester gt with about 200k on the clock! It runs nicely but on hard acceleration, especially up hill it seems to have a slight thump that happens maybe every second and gets faster as the car gets faster then goes away at higher rpm. I would love some help pleaseeeee 🙂🙂
Thanyou
G'day & welcome aboard!
It would help if you could identify from where the sound is coming e.g. front, rear, center, left right etc?
Also:
Thanks for your interest Kevin! It’s hard to tell I actually haven’t been able to pinpoint where it’s coming from? It seems to happen if I am in let’s say second and going slow then put my foot flat and when it gets to maybe 3k rpm it starts to mske this sound?
you need to put this up on a floor lift and run it while off the ground, to me it sounds as if it could be a differential bearing, but a main drive shaft u joint or carrier bearing is also possible, . lift and find it first then see, ........ stop flooring the engine for now, until you repair it
