2005 Forester 2.0X Manual
Hello!
I'm about to do the rear shoes, but I can't find a fitting kit (springs etc).
There are loads for the disc+drum versions, but mine only has drums at the back and I'm assuming that the fitting kit would be different since the shoe size is bigger (229mm vs 170mm?).
Any clue as to where I can get a kit in the UK would be ace!
Thanks a million,
Adam
· Don, King of the parts diagram
MY11 WRX STi Sedan 6MT
Reactions: The Hoff
2003 Forester AW Manual with low ratio
As per Dons parts list, think you may need to work out exactly what you need and see if they can be ordered via a dealer.
Also be aware if you get new shoes, the handbrake levers (26708)won't come with them, and you'll need to take off and re-use the levers from the old shoes. May need new "E" clips to fit them depending what condition the old ones are after removal.
Spring Washer 26788A may or may not be needed depending upon date of manufacture.
