Besides tires, I would use lowgear (1st/2nd) assuming you have an auto I forget. Besides that a semi-sideways technique when in trouble as you did is really all you can do.
I had my X-ice2s on because it was late fall, we didn't hit snow but there had already been snow on the ground. Some of the guys had gravel rally tires, but most had winters or all seasons..What kind of tires are they and you running? It is near impossible to get something close to an AT tire in 225/55R17.
An AT will do worse than most winter or M+S tires in mud, I found the goodyear tripletreds to be pretty good (they're on the outback in that picture, I was able to get back to the main road with just a pull out of the hole it had dug itself into). Point the car where you want to go and give it gas, off throttle will just cause it to understeer/slide out. On throttle you'll get a little drift going on and then you just need some counter steer to keep it under control. Practice driving offroad, just like in snow, is the most beneficial to keeping the car under control.What kind of tires are they and you running? It is near impossible to get something close to an AT tire in 225/55R17.
That reminds me of the graduation runs on slippery mud at the Primitive Rally School a couple of weeks ago. The one car that beat everyone's time in the end was a bone stock Toyota Yaris with snow/mud tires. He had a completely unspectacular run, and left all the AWD Subies and Evos in the dust... or mud, so to speak. Goes to show what a difference the right tires for the job can make.I had my X-ice2s on because it was late fall, we didn't hit snow but there had already been snow on the ground. Some of the guys had gravel rally tires, but most had winters or all seasons..
the fastest car through the worst stage was a beater 90 prelude on winterforce tires..:icon_redface: brought home the message of being first vs. bringing the car home in one piece.
correct!I wasn't sure that if I am heading for the ditch if I should point the FXT in teh direction I want to go and begin to give it some gas.
but but but - turning on the A/C in my auto increases revs.Put it in the lowest gear you have, turn on the A/C, and let off the brakes when you need to change direction or anything.
An auto hurts you a little in this situation. It is, inherently, going to be less responsive than an MT.
AT tires are some of the worst for mud actually... my Geolander AT/s do OK, but with mud and sand AT's seem to hinder more than help.What kind of tires are they and you running? It is near impossible to get something close to an AT tire in 225/55R17.
