1 - 2 of 2 Posts
1999 Forester L
i have a 99 forester and just recently my drivers window will not roll down at all. this began in the last week. i havnt had this problem before and all of the other windows are fine. its not because of ice or anything. also my drivers door pannel is loose. any suggestions would be appreciated
2006 X Premium
Do you hear any effort being made by the motor when you attempt to lower the window? Remove the panel and make sure that the wiring for the harness is securely attached to the motor. While you're at it, check if the motor harness is receiving voltage when you press the window switch in the down position.
1 - 2 of 2 Posts
