1 - 11 of 11 Posts
'03 XS MT PSM
2015 Ford Focus ST
After yesterday's torrential downpours and high winds, my drivers door now seems to be very heavy and does not close with the ease that it used to.
I looked to see if there was a stick or something else stuck in teh door jamb, but no. The rain & wind probably have nothing to do with it but I thought i'd throw it in there to paint the picture of when it started.
Any ideas?
Hmm, maybe some water got into the door through the seals? Probably not, but I can't think of anything that would make the door seem heavier.
'03 XS MT PSM
2015 Ford Focus ST
I'm going to scope it more closely in the AM. It just happened all of a sudden. Everytime I go out to see, it's dark. :( I can't see how it would have taken on water. My guess is it's just a lube issue. Daylight will tell...
'03 XS MT PSM
2015 Ford Focus ST
I just IM'd with a friend who works at the local Suby dealer... he said the door is probably filled with water and that the drain plugz are stuffed. Nice. That should be a hoot tomorrow morning. Hopefully it won't freeze tonite.
'03 XS MT PSM
2015 Ford Focus ST
Are the door drain holes square? Just want to make sure i'm looking at the right thing.
Yep - I found one around the middle of the bottom of the door frame and stuck my little finger in - totally covered in red dirt; from the Cape York trip I suspect :lol:
'03 XS MT PSM
2015 Ford Focus ST
Discussion Starter · #10 ·
I stuck a big fat plastic cable tie up each of the drain holes and they all seemed clean. I sprayed some lube on the hinges too. Seemed to help. What kind of lube does one put on a door hinge?
1 - 11 of 11 Posts
