I had a problem with the Driver Monitoring System today. On a regular commute route in daylight, I got the "KEEP YOUR EYES ON THE ROAD" (or whatever it says) message and the usual alert beep. Instead of disappearing after five seconds or so, the alert remained on the display, and repeated every 15 seconds or so. It would disappear momentarily, then come up again. I was being careful to look straight ahead, but it made no difference in the alerts.
I cycled the system several times by turning off the sensors and then turning them back on again, with the same results. This continued until I reached my destination and turned the engine off. When I started back up again, an hour or so later, the problem had disappeared.
I wasn't wearing a hat or anything different than what I normally wear when I drive. e.g. there wasn't any barrier between the cameras and my eyes other than the glasses I normally wear.
I appreciate this might have been a momentary glitch, but I'm wondering if anyone has seen a similar problem, and if so, what you did about it.
