Hey all, been lurking here for a bit but first time posting. I have been scouring all these boards hoping to find a solution to my problems, but no luck. Heres some background info. I have a 2001 5spd L Forester, with about 128k on it. Starting last fall I was getting some off and on scraping, clunking, and rubbing noises under the car (I was initially thinking bad u-joints). I took it into a local shop, they didn't hear anything and said everything looked good.
This went on for a while, until eventually one day I got a bouncing feeling in the back end when I first started driving in the morning. If I put the car in neutral the bouncing stopped. This would only last for about a half mile then smooth out. Took it in and was diagnosed with a bad rear differential (they said they see it all the time?). Shop replaced it with a used one, then found that my u-joints were seized and super crunchy, so they swapped the driveshaft for a used one as well.
I still have the bouncing in the back end first thing in the morning, though goes away after pretty quick and its not nearly as bad. However, ever since that work was done I have a vibration at highway speeds, but it only starts after I have been cruising at 50+mph for at least 5-10 minutes, and I feel from the middle/back of the car. No shake in the steering wheel, and no wobbling feeling. Just vibration. Before that everything is perfectly smooth. I brought it back to the shop that did the work, but they didn't take it for a long enough test drive on the highway and were unable to find anything wrong.
Just recently brought the car into another shop to get some fresh eyes on it. They took it for a long test drive, felt everything I was talking about. They check the u-joints on the driveshaft and said they were pretty notchy and most likely the problem. I pulled the driveshaft out last night, and they were right, all the u-joints were pretty rough feeling. Put in a new aftermarket, no changes at all in the symptoms. Bouncing from the back end still first thing in the morning, a vibration after driving on the highway for 5-10 minutes, but drives perfectly smooth other than that. Not sure where to look next. Could the replacement rear differential be causing this, or did something completely different start showing symptoms at the same time the work was first done.
