P
PSi3
·Guest
Hi all,
After discussions with Roo we have offered one of our Data Monitors as a prize for a Donation Raffle to raise funds for subaruforester.org
For those that are not aware of our monitors here are a few details..
The Data Monitors plug directly into the vehicles OBD ( On Board Diagnostics ) socket, power and ground is also taken from the same socket allowing for very simple installation.
The following information is available from most ECU's
LIVE DATA MONITORING (display layout can be custom configured)
Battery voltage - Volts
Engine Speed - RPM
Vehicle road speed - MPH or KMH
Coolant temperature - Degrees C
Intake temperature - Degrees C (This is not charge temp.)
Fuel injector pulse width - Milliseconds
Ignition point - Degrees BTDC
Knock correct - Degrees (Ignition Timing)
Lambda air/fuel ratio
Throttle position - %
Air flow meter mass - Grammes Per Second
Boost pressure - Bar (user selectable from either ECU or External sensor)
Oil Pressure (additional sensor required)
Oil Temperature (additional sensor required)
Exhaust Gas Temperature (if available from ECU)
READING OF CURRENT AND HISTORIC FAULT CODES
ECU/FAULT CODES RESET
SHIFT LIGHT CONTROL WITH ADJUSTABLE SETPOINT (LAMP NOT SUPPLIED)
EXTERNAL ALARM/SHIFT LIGHT OUTPUT
USER ADJUSTABLE ALARMS MONITORING
Battery voltage low
Battery voltage high
Boost pressure (user selectable from either ECU or External sensor)
Coolant temperature
WATER INJECTION/NITROUS CONTROL
RECORDS PEAK READINGS (USER RESETABLE)
Engine speed - RPM
Boost Pressure - Bar (user selectable from either ECU or External sensor)
Road Speed - MPH or KMH
Coolant Temperature - Degrees C
CLOCK
USER SELECTABLE OPTIONS:
BAR or PSI
MPH or KMH
Degrees C or Degrees F
Boost ECU or Boost External
Lambda or AFR
MPH TO KPH
Data monitors will fit into any Forester with a spare single DIN slot, we also offer pod mount versions using Genuine subaru pods as below...
'98 - '02 Forester
http://www.subaru.co.uk/IMGGB/WWW/S...8B28213A3329203580256D59005597DB?Opendocument
'03 - '06 Forester
A similar Subaru pod is available for these model years ( i have one fitted in my vehicle ), Subaru part no. H0010SA000 ( described as - Navi Panel Kit).
If a spare single DIN slot is not available the data monitor can be fitted using the above pods, available from Subaru dealers. or via PSi3 Ltd.
Over the past 3 years we have sold in excess of 2500 Subaru specific Data monitors.
The data monitor will work on post '98 Subaru's with a standard ECU - including re-mapped/re-flashed ECU's.
Please note - Unit features may vary according to specification of vehicle ECU supplied data.
We hope to be regular contributors to this forum and aim to help wherever we can so please feel free to contact us at anytime.
Roo will be along soon to fill in the details for the terms of the Donation Raffle
Many thanks
Simon Jarvis
[email protected]
www.psi3.co.uk
Engine Speed - RPM
Battery voltage low
Coolant temperature
Engine speed - RPM
CLOCK
BAR or PSI
MPH or KMH
Lambda or AFR
MPH TO KPH
'98 - '02 Forester
'03 - '06 Forester
Many thanks
Simon Jarvis
[email protected]
www.psi3.co.uk
