Does 2019 manual rear gate allow memory height set?
4131 Views 8 Replies 5 Participants Last post by  Sdcerreta
Does anyone know if the manual tailgate in 2019 forester allow you to set rear gate opening height? I am thinking about getting the base model which does not include the power rear gate but the rear gate opening seems too high. I am wondering if you can set at a lower opening height?
G'day & Welcome aboard!
I don't know but am guessing you'd probably need to replace with shorter struts or have some pressure taken out of the existing struts. Over here I've used a mobile service to have stuff like this done.
The Touring trim has a height set/memory function. I can't speak to the other trim lines.
In the attached photo, the control is third button from the left, top row.
I have a SPORT with the power rear hatch...it is the same as @copwriter stated above and I have the same switch on the dash to adjust the height.
Hey Guys - this thread is not about the powered rear gate; a reminder:
My bad. We now return you to our regularly scheduled program.
A manual tailgate has no motor so, therefore, has no way to control the height. It's either open or it's closed...period1
^ as I have suggested the struts can be modified
Nope. This can only be done with the power option.
