ok so this weekend i finally installed
Group-N engine mounts, pitch stop, trans mount
KB trans x-member bushings, rear diff outrigger bushings
WL steering rack bushings
Torque Solutions driveshaft bushings
everything is in good and working order.. nothing loose.. no leaks (i think) but i hear my "intake-sucking-in-air" A LOT more.. is this normal? im gonna double check i dont have leaks but, i wanna see if these mounts brought that "intake-sucking-in-air" sound out more for anyone else..
i DO have an APS 65mm CAI and STi TMIC... so, im used to those sounds but its much more louder and with the windows down.. i can hear it on the driver's side now..
car drive's fine.. no change in gas mileage (i think) n boost still holds fine
i'm aware that all these mounts make everything in the drivetrain n engine louder (which they DEF do... but i like it :biggrin
.. but i didnt think it would make the "intake-sucking-in-air" sound way more louder.. not that it bothers me.. just wanna make sure this is normal
any suggestions? thanks
BTW.. did all these mounts + WL 24mm/22mm (F/R) sway bars too
car.. is... freakin.. amazing right now
