1 - 20 of 43 Posts
Fast & Dirty
2009 Forester XT 4 speed auto
Like many of us on the forum we really liked the look of teh matte black painted grille insert from a 2009 FXT.
Well, I will outline the steps needed to get the grille insert off so it can be painted WITHOUT taping.
First step:
Remove bumper.
http://www.subaruforester.org/vbulletin/f80/how-remove-bumper-2009-lots-pics-61344/
Step 2:
Remove complete grille. 2 screws located at the bottom of grille.
Step 3:
Remove 10 small black phillip screws.
Step 4:
Gently use a small flathead screwdriver and pry the tab on the very top right or left of the back of the grille. As you begin to separate the 2 pieces it should continue to allow you to separate the entire thing in one movement. Be slow and gentle.
Step 5:
You should now be holding 2 pieces. One shiny chromo and the other is the insert.
Step 6:
Clean the insert
Step 7:
repeat step 6. You cannot paint anything if it is dirty. Period. Do a half donkey job cleaning will give you a half donkey result.
Step 8:
Prepare insert for paint. I built a support for the insert that will allow it to hang securely without moving. I did this so I can easily apply many light coats of paint.
step 9:
patience. Prep work in painting is everything.
backside of chrome piece after insert removal
The 4 screws help hold the insert when painting
I hope this helps and give you the results you want. As always, TAKE YOUR TIME.
before
After
2009 Forester XT Limited
Vey nice.......Good write-up. Thanks.
I was thinking of maybe gloss on mine. Not sure how it would look but I guess I could try it and if I did not like it then go to flat or semi. Maybe I should start out with semi first since I keep everything (plastic exterior parts) dressed most of the time.
Fast & Dirty
My plan now is to take off my other grille, when I get my FXT back, and start preparing for my light mod. I am hoping to cut a rectangle in teh grill and have my Hella 450s poke through.
I am doing a little research myself to see if just the center piece can be ordered. I wanted to cut out some of the little rectangles that seem to block air flow. I don't think it should be an issue since the sport grill is just basically mesh and wide open from what I can tell. With the exception of last week, living is FLA is about cooling! :biggrin: Then I will paint the sucker bright orange........................Jk'ing.
Fast & Dirty
Discussion Starter #13
I'll be home tomorrow. I have also booked some Subie time Saturday morning to install the grill and install my plate (I remove it before any visit to the dealership)
Cheers
2009 Forester
What kind of paint did you use??? any prime???
Thanks
2015 Forester 2.0 xt Tour
Please, take some pictures of your painted grill after a year. Also, how many times you had to touch up the spots of chrome that re-appeared after high speed bug hits and other small flying objects.
Yea, I am being sarcastic but I just don't see how paint over chrome will hold up.
love my Forester....
I'd paint those horns black to eliminate the rice factor but otherwise, it looks good.
1 - 20 of 43 Posts
