1 - 20 of 26 Posts
2014 Forester XT CVT - EyeSight
I'm going to get a set of winter wheels, probably not getting TPMS, just wondering if we can disable the TPMS?
2008 Forester X Premium 5MT
nope, you can't.
I shouldn't say you can't. It was not easy on the early Subaru models that used standalone TPMS modules. It could be done but required a fair amount of DIY work, this thread has all those options listed through out it www.subaruforester.org/vbulletin/f72/tpms-sensor-replacement-33939/
Now the newer models have integrated the TPMS into the keyless entry module in the rear quarter panel. As best I know no one has undertaken the task. You would be the first.
there is always the classic black tape mod.
2014 2.0 XT yes
This is something they should steal from Toyota. The system in our Lexus has room for two sets of sensors. Our winter wheels have monitors in them, and you just switch over to that set with the steering wheel controls.
1999 Forester 5MT
As long as it's compatible with 2014 Foresters, the ATEQ Quickset will allow you to swap out sensor IDs for a summer and winter set. A bunch of STI guys use it.
GMs, I think is better. You can learn new sensor IDs with out the need for any tools. Simply set the module into a learn mode via a song and dance in the cabin. Ignition on, parking brake on, lamp switch of..... horn beeps 4 times. In order drop pressure in tires until horn beeps. Programing is done, air your tires back up.
These are fine options if the OP wants to buy sensors, which they don't.
If you are buying sensors, the easiest thing is to by the EZ-Sensors that can clone the original TPMS sensor IDs allowing you to switch tires out at will with out the need to do a darn thing. No extra tools to buy, no need to pay a shop for a relearn each time, just buying sensors you would have to buy anyway and a one time cloning of the sensors.
1999 Forester 5MT
This may just be my limited experience, but these don't seem to work well with Subaru's current TPMS implementation. I've seen varied results using them on 08+ Imprezas, with a nod going towards them not working right. Hence why people buy normal sensors and just use the Quickset to reprogram the IDs in the TPMS module.
Lifer
2015 Forester CVT
The ATEQ QuickSet IS compatible with the 2014 Forester 2.0 Turbo. When I did it a couple of weeks ago, the 2014 Forester was not in the vehicle list. The QuickSet tech folks had me use the 2013 Impreza selection as the model, and the device worked.
I have not had any issue with the ones I put in the Misses winter wheels, nor has any one else I know who has used them.
I just run with the light on in mine when the winters are on, but I am all about the misses having hers actually function.
2013 forester 2.5X automatic
No need for the black tape fix, I used to run my Vibe all winter with the TPMS light on, after a few days I would get accustomed to the light and not even notice it.:woohoo:
2014 Forester 2.5iPremium 6sp Manual
I was a little concerned about the annoyance factor of TPMS and ended up getting sensors with my winters. I'm still waiting for Discount Tire to be able to flash the 2014's. Seriously, it's barely noticeable. A small, silent yellow light on the dash.
TPMS is a great feature, particularly for anyone who frequents rough roads. After an extended road trip out west last year, I picked up leaks on 3 out of 4 of my F150's tires. All at different times and on different roads.
They weren't immediately noticeable and I was able to get them fixed before hitting the highways. It provides some peace of mind. Don't bother disabling it and if you have it, you should be happy you do.
2014 2.0XT Premium CVT
RiffleKing- thanks for the post about Discount Tire not able to flash the 2014s. I had a new wheel/tire set installed by Discount today, with new after market TPMS and despite their attempting to program twice, I still have the TPMS alert. They are telling me the '14 is in their database. . sounds like they aren't setup yet to do it though? I'm curious what they told you. .
Thanks!
Lifer
2015 Forester CVT
An option to try
Thanks!
For what it's worth, a tire dealer tried using the 2012 Impreza on on my '14 2.0 XT and that worked. I think his electronic tool was Snap On. Maybe if your Discount Tire dealer gives that a try, you (and the warning light) will be off and rolling.
2014 Forester Limited CVT
Thanks!
I'm wondering if they lied about the '14 in their database. I just bought wheels and tires 2 weeks ago, and they didn't even have the '14 Forester stock wheel size. He told me he was going off the '13, which has a stock size of 16in, not 17in like our forester. Our invoice even says "The tire and/or wheel you have chosen is different from the original equipment provided with your vehicle and may change its handling or stability characteristics." because I had to give him the real stock tire and rim size.
In fact, if you go on the Discount Tire website, if you select model year 2014, they don't even have Subaru on the list, which means at least their customer facing system has no data for any '14 Subarus.
Thanks!
County,
I was told that it should be available by the end of the year. He showed me the little gadget he was using and how it only showed the 2013 model. I imagine that they just didn't know what they were talking about in your situation.
Skidplate,
Thanks for the tip! I will try to stop by the shop soon and have them try it.
Schrobo,
Yeah, I noticed that and just ordered through the local store. They didn't give me any problems and ordered the wheels and tires I wanted. My receipt just lists my vehicle as a 2013. I did have to go back and have them torque the wheels down a hair more to 2014 spec. They said to come in when the vehicle is in their system and they'll update the receipt.
I've been really happy with the service aside from this. They also refunded the cost of one sensor for my trouble.
Which wheels did you end up getting?
Could be the kid yesterday at Discount just didn't know what he was talking about. . different knowledgeable crew today though . . they told me the '14 wasn't in the system. I suggested trying the '12 or '13 Impreza and the '13 Impreza worked! Note though they needed the original rims with TPMS to do a de-program procedure first. Dialed-in and happy now!
1 - 20 of 26 Posts
