2010 Forester 2.5X
I am replacing my engine air filter (2010 Forrester, non-turbo), but forgot to check the correct direction of it when pulling the old one out.
Anyone be so kind to check yours and tell me what is the correct direction of it? The filter is square in shape. There is a small blue mark on one side. Is this side supposed to be up?
The new filter is bought from Subaru dealer. It is exactly the same as the old one.
Thanks a lot!
2019 Crosstrek 2018 XT
Air flow goes through the "pleats" first. So the "smooth" side is toward the engine.
If its like the 08 the "pleats" are down.
2010 Forester
Picture to support what adc said: (also on pg 11-16 of owner's manual).
Regards,
paul...
2018 2.5i Premium CVT
It should be easy to determine which part of the filter housing is the inlet and which is the outlet. Then compare the old filter to the new one. Dirty side of the old one = inlet side.
2010 Forester 2.5X
Thanks guys. I know what is the inlet and outlet side. This is obvious. What i am asking is the up-down direction. Or it doesn't matter because it's square?
Thanks!
2015 XC diesel CVT
Doesn't matter. Although, you *might* find that larger debris falls off easier if the pleats are vertical...
