Just received my order of LEDs from Diode Dynamics (Diode Dynamics) for my 2014 XT Premium. Couldn't wait to get rid of the dim stock bulbs that I KNOW everyone else is irritated by as well. Especially the Cargo Area lighting. Terrible place to put a light in my opinion. My order is as follows:
2003-2014 Subaru Forester Map Light LEDs (pair)
Color: White
Brightness: Stage 2
$14.99
2003-2014 Subaru Forester Dome Light LED
Color: White
Brightness: Stage 2
$7.49
2014 Subaru Forester Trunk Light LED
Color: White
Brightness: Stage 3
$13.49
1998-2014 Subaru Forester License Plate LEDs (pair)
Color: White
Brightness: Stage 2
$7.49
2014 Subaru Forester Door Light LEDs (pair)
Color: White
Brightness: Stage 2
$11.99
REVIEW:
Installing the lights was a breeze. Literally 15 minutes TOPS for all lights.
Just pop off the housing with a flat-head screwdriver. CAREFULLY insert the screwdriver in the seam and wiggle slowly. The license plate light replacement is in the manual. Just follow the instructions in there.
The only "issue" was the cargo area Stage 3 12-LED panel. As stated in the description on the item's page, if you want to use the full 12-LED panel, you WILL have to mount it outside of the light housing with the included 3M Tape. Otherwise, like another user stated, you can cut off a row of 3 LEDs and trim the corners to get the panel to fit INSIDE the housing. I did this with great success. It is not as bright as 12-LEDs (obviously), but it is a vast improvement over the stock bulb. I can actually see my cargo area now.
With the Approach Lighting on the side mirrors, the White LEDs are the way to go for all interior lights as well as the license plate lights. They match almost perfectly.:bling: Best $60 spent. Will be looking to upgrade headlights soon.
Color: White
Brightness: Stage 2
$14.99
Color: White
Brightness: Stage 2
$7.49
Color: White
Brightness: Stage 3
$13.49
Color: White
Brightness: Stage 2
$7.49
Color: White
Brightness: Stage 2
$11.99
REVIEW:
