Hey guys and gals,
doing the 30K maintenance on a 2006 forester non-turbo. Looks like the front diff nut is a star bit and the rear nuts are square. For the rear I was trying to use a 3/4" square bit with a ratchet wrench it was fairly loose fitting and neither of the two would budge. Looks like maybe some kind of thread lock might have been used. To bad Subaru did not use the same type that are on the oil pan and trani pan.
Question is any ideas on how to loosen stubborn nuts and anyone know the correct type and size of buts I should be using on the ratchet?
Also, any other maintenance to be done above and beyond what the chilton or hayes manuals say to do?
thank you and have a great day.
Craig
Craig
