Hi all,
This is my first attempt to change the automatic transmission fluid on a 2006 Subaru Forester 2.5XT after reading all the helpful tips & tricks here. It is definitely a task that I can manage so I think.:bananapartyhat:
I am almost certain this is the correct drain plug and filter. Especially the filter next to it said transmission filter. The funny thing is after refill (3-1/2 quarts) fluid into the dipstick hole and drove around the block. The transmission sound rough and sluggish so I check the fluid level which was slightly overfilled. Therefore, I went back to the drain plug to release the excess but found it empty. Where has the fluid gone? Did I really mess it up this time?:icon_question:
I did not drain the engine oil by mistake since I do my own oil change regularly. Furthermore, I did not drain the differential fluid neither sine it requires T70 star bit that I do not have.
Please help. I am carless and stranded. Thank you in advance for all your assistance. God bless.
I can not post URL of the relate photos here due to minimum post not met. May be I can PM when you response and post for me. Thanks
